BobbyWang
Mar 18, 2024Aspirant
Adding 2nd satellite works for about a day, then 2nd satellite shows as "disconnected"
Mesh works with router & one satellite. Adding 2nd satellite works for about a day, then 2nd satellite shows as "disconnected", and Chromebook cannot connect with "DHCP Lookup Failure" error. Curren...
- Mar 26, 2024
When you factory reset, it's best to FR both RBR and RBS to ensure getting all units into a clean state.
Sounds like it's working now. Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
