lee153
Jul 22, 2024Aspirant
adding a 2nd 2.4 ghz router
Can anyone tell me how I can install a 2nd 2.4 ghz router , I have the orbi 970 wifi 7 for a month now , I have 5 devices that wont connect to my wifi , I have spent countless hours trying , Liftmast...
lee153
Jul 29, 2024Aspirant
I defaulted my 970 and started over again , I did make sure my IoT settings were for 2.4 ghz , I was able to add 2 more devices , My LG thinq and Nortiz Tankless hot water heater , and my Bose Soundbar , But ..... the Liftmaster Side mount garage door opener still wont go , it shows up during the procedures but it never gets to the point of wanting to join the loT network , I see on youtube many people having same issues ! it worked on previous original Orbi from 3 years ago , I have also set up and tried " guest" at this point I am stuck , I will call Liftmaster to see if they have any ideas , thanks all for the ideas , I was able to set up 3 mote devices with the loT , just this one left .......
Jul 29, 2024Guru - Experienced User
OK sounds like more progress. Seems like LiftMaster needs to help out on this.
Ask about any FW updates for there stuff as well.
Good Luck.
