Tallrandal
Feb 02, 2025Guide
Adding Orbi 970 fan
I’m planning to add a fan to my Orbi 970 to help extend its lifespan, and I’m curious about how others have configured their setups. For instance, do you typically mount the fan on top to direct hot ...
Feb 02, 2025Guru - Experienced User
I keep one of these on top of my RBR pulling air from bottom to top or pulling air upwards from the RBR:
I've never used a fan with any of my netgear routers. At any given time, I've got about 120-150 devices connected to my network. While its warm, I wouldn't say its hot. CPU load sitting around 20-30% without armor/parental controls active.
