Tallrandal
Feb 02, 2025Guide
Adding Orbi 970 fan
I’m planning to add a fan to my Orbi 970 to help extend its lifespan, and I’m curious about how others have configured their setups. For instance, do you typically mount the fan on top to direct hot ...
Roc1
Feb 02, 2025Luminary
I’m with FURRYe38 , I have the same unit just sitting on top of the unit.
There’s a fine line on fan diameter for top use. There’s an 85mm solid round plate at top center on the RBE’s. Your fan will work better if the blades extend beyond the center plate so it can pull air up thru the RBE. But, if you go beyond a 145mm fan-base width, it will hang over the outside of the RBE, and end up pulling most of the fan air from the outside top of the router and not up thru the inside of the router (pulling air thru the router has more resistance than pulling unobstructed air from the outside of the router).
I have a 120mm diameter fan (I think that’s what furry has also) and it covers the top of the router (not an exact fit because my 120mm fan-base is a square shape while the RBE top is basically a modified triangular base.
You are wise to add this “insurance”. I use them on the router and satellites.
- plemansFeb 02, 2025Guru - Experienced User
a fan is never a bad idea as heat is the death of electronics. and with that expensive of a unit, its a pretty cheap investment. Its just not something that you have to have. Thats all I was going for with my setup description.
- CrimpOnFeb 02, 2025Guru - Experienced User
In the past year or so, there were posts in the forum of specific Orbi routers overheating, while other apparently identical units did not. At the time, there was speculation that perhaps some units came out of the factory with inadequate thermal paste. My opinion is:
- If manufactured correctly, these devices should not overheat in temperatures from 32 to 104 degrees Fahrenheit.
- Adding a cooling fan cannot possibly harm a router, and may actually increase performance or lifespan.
- TallrandalFeb 02, 2025Guide
I completely agree that adding an external fan to the router isn’t essential. However, providing extra airflow for a device that lacks it can significantly improve overall air circulation. This enhanced airflow helps keep internal components cool, ultimately extending the device’s lifespan. For example, the location of my Orbi router doesn’t have optimal airflow, and during the summer months, it tends to get quite warm. Given these conditions, I prefer to invest a modest amount in an external fan to help prolong the life of my devices.
I was just cruious for those who do want a fan, how did they add it to the outside...
- FURRYe38Feb 02, 2025Guru - Experienced User
I've been using fans on routers for 10 plus years. User choice and not required. Ya for flat styled routers, place fan on botton of router and push air upwards. For these cylinder style cases, a fan on top and pulling air upwards from the top of the case has worked for me.
