Stallion69
Nov 16, 2024Tutor
Additional Satellite to WiFi 7 970 Series
I just hooked up the ORBI WiFi 7 970 Series router with 2 satellites. All are hard wired (Backhaul). I was gonig to add an additional satellite at the other end of the house, but it will not be har...
Nov 18, 2024Guru - Experienced User
You must have a massive house to need 3x satellites. They provide quite a bit of coverage, and you can actually make speeds/roaming worse with too much coverage.
Stallion69
Nov 19, 2024Tutor
It's just when I walk further from the satellite, I notice the wifi get weaker and I am less than 30ft from it.
