Stallion69
Nov 16, 2024Tutor
Additional Satellite to WiFi 7 970 Series
I just hooked up the ORBI WiFi 7 970 Series router with 2 satellites. All are hard wired (Backhaul). I was gonig to add an additional satellite at the other end of the house, but it will not be har...
Stallion69
Nov 19, 2024Tutor
Size of home is 2500 square ft. Router is in basement and both satellites are upstairs. They are hard wired back to the router. Distance shouldn't be an issue since they are hard wired. I wanted to add one more satellite downstairs hard wired back to the router as well so the other side of basement is covered. I have cement floors on first floor.
Nov 19, 2024Guru - Experienced User
That size of home, Should only need the RBR and one RBS...
