Dfran1
Oct 14, 2023Apprentice
Advanced Wireless Settings (MLO Backhaul) Enable 240MHz Bandwidth
in advanced, advanced, wifi settings Advanced Wireless Settings (MLO Backhaul) Enable 240MHz Bandwidth What does this do ? is it just for backhaul from router to satellites OR...
- Oct 15, 2023
Combines having both 5Ghz and 6Ghz backhaul radios running at the same time. If conditions are good. IF conditions are not prefereanble or problematic, the system will drop to 5Ghz (SLO) backhaul.
Advanced Wireless Settings (MLO Backhaul) Enable 240MHz Bandwidth What does this do ? is it just for backhaul from router to satellites OR is it for devices to satellite or router?
I can not seem to find any info on it
Thank you
schumaku
Oct 15, 2023Guru - Experienced User
In Netgear terms, backhaul is the connection between the Mesh nodes devices, so the data backhaul between router and satellites.
No idea by how far Netgear does intentionally restrict the MLO usage to the backhaul, avoiding or blocking out compatible MLO capable wireless clients now or in the future - operating within the standards.
