Dfran1
Oct 14, 2023Apprentice
Advanced Wireless Settings (MLO Backhaul) Enable 240MHz Bandwidth
in advanced, advanced, wifi settings Advanced Wireless Settings (MLO Backhaul) Enable 240MHz Bandwidth What does this do ? is it just for backhaul from router to satellites OR...
- Oct 15, 2023
Combines having both 5Ghz and 6Ghz backhaul radios running at the same time. If conditions are good. IF conditions are not prefereanble or problematic, the system will drop to 5Ghz (SLO) backhaul.
Advanced Wireless Settings (MLO Backhaul) Enable 240MHz Bandwidth What does this do ? is it just for backhaul from router to satellites OR is it for devices to satellite or router?
I can not seem to find any info on it
Thank you
Straq
Nov 17, 2023NETGEAR Expert
Hi There,
Engineering team here. To be more precise your system by default should already be running in 5GHz + 6GHz MLO Backhaul with a bandwidth capacity of 160MHz which is still extremely fast. When enabling 240MHz, you are enabling even faster speeds due to higher bandwidth! But there is a catch. In order to fully benefit out of 240MHz it requires using a DFS channel which is susceptible to a DFS radar event where bandwidth might have to be lower or channel has to change completely
More info here: SmallNetBuilder's Wi-Fi Dynamic Frequency Selection (DFS) FAQ - SmallNetBuilder
- AbbasRazaNov 21, 2023GuideSo in other words, your saying that we should not enable 240mhz on our orbi 970?
