TOPS119
Jan 29, 2024Luminary
After the update my iPhone 15 pro max stop showing correct speed
Well as I stated above my iPhone 15 pro max stop showing the correct speed on the speed test. I have about 250mbps connection @ home , it now only shows 64mbps, on the Mac it shows the full 250mbps i...
Jan 29, 2024Guru - Experienced User
Has the the Orbi system been powered OFF for 1 minute then back ON since after the FW update?
Is Protected WiFi IP address enabled on the iPhone?
What iOS is on the iPhone?
- TOPS119Jan 31, 2024Luminary
Yes orbi was restarted for the 1min
Private wi-fi address is on
its on the latest os
- FURRYe38Jan 31, 2024Guru - Experienced User
Restarted or Powered OFF then back ON after 1 minute?
Does this still happen if you disabled Private WiFi address feature on the phone?
There a version number of the iOS on the phone?
The iPhone is on iOS 17.3
The thing is it actually works some times.. but if I check it later its not working
