TOPS119
Jan 28, 2024Luminary
After the update my iPhone 15 pro max stop showing correct speed
Well as I stated above my iPhone 15 pro max stop showing the correct speed on the speed test. I have about 250mbps connection @ home , it now only shows 64mbps, on the Mac it shows the full 250mbps i...
Jan 29, 2024Guru - Experienced User
Has the the Orbi system been powered OFF for 1 minute then back ON since after the FW update?
Is Protected WiFi IP address enabled on the iPhone?
What iOS is on the iPhone?
TOPS119
Jan 31, 2024Luminary
Yes orbi was restarted for the 1min
Private wi-fi address is on
its on the latest os
- FURRYe38Jan 31, 2024Guru - Experienced User
Restarted or Powered OFF then back ON after 1 minute?
Does this still happen if you disabled Private WiFi address feature on the phone?
There a version number of the iOS on the phone?
- TOPS119Jan 31, 2024Luminary
The iPhone is on iOS 17.3
The thing is it actually works some times.. but if I check it later its not working
Thanks for the version #.
Possible there maybe some issues still happening between Apple and NG. I haven't heard anything official if all that's been fully addressed.
