TOPS119
Jan 28, 2024Luminary
After the update my iPhone 15 pro max stop showing correct speed
Well as I stated above my iPhone 15 pro max stop showing the correct speed on the speed test. I have about 250mbps connection @ home , it now only shows 64mbps, on the Mac it shows the full 250mbps i...
TOPS119
Jan 31, 2024Luminary
Yes orbi was restarted for the 1min
Private wi-fi address is on
its on the latest os
Jan 31, 2024Guru - Experienced User
Restarted or Powered OFF then back ON after 1 minute?
Does this still happen if you disabled Private WiFi address feature on the phone?
There a version number of the iOS on the phone?
- TOPS119Jan 31, 2024Luminary
The iPhone is on iOS 17.3
The thing is it actually works some times.. but if I check it later its not working
- FURRYe38Jan 31, 2024Guru - Experienced User
Thanks for the version #.
Possible there maybe some issues still happening between Apple and NG. I haven't heard anything official if all that's been fully addressed.
I never tried turning it off I will do and report back
