TOPS119
Jan 29, 2024Luminary
After the update my iPhone 15 pro max stop showing correct speed
Well as I stated above my iPhone 15 pro max stop showing the correct speed on the speed test. I have about 250mbps connection @ home , it now only shows 64mbps, on the Mac it shows the full 250mbps i...
TOPS119
Feb 01, 2024Luminary
It shows 5gh + 6gh
isp is Digicel
Caribbean region
Feb 01, 2024Guru - Experienced User
AH, OK, explains that a bit. There seems to be in region and out of region UI behaviors. I'll check on this to be sure for you.
As long as you see 5+6Ghz there, your good. Means MLO is enabled and working.
