Chuck_M
Dec 07, 2024Mentor
AP Mode "Attached Devices"
My Orbi is in AP mode behind a pfSense firewall providing DHCP along with a piHole providing DNS. Things seem to be working fine with one odd anomaly. Of course in the AP mode, the menus in the ...
- Dec 09, 2024
That depends on the pfSense box.
The BE971 router has
- WAN port rated to 10G. If the pfSense has an Ethernet port capable of 2.5G, then the Orbi port will connect at 2.5G
- One LAN port rated to 10G. If connected to the 2.5G switch, then it will also connect at 2.5G
- (4) 2.5G Ethernet ports. Any of these could be connected to the 2.5G switch.
(only connect the 971 to the switch with one cable - your pick of port)
This router is about as future proofed as it could get.
Chuck_M
Dec 09, 2024Mentor
This is really good info... for which I am very grateful for you taking the time!
FInal question before we put this to bed.
I have a 2.5gig connection via Cox.
If I connect Orbi directly to pfSense (The yellow WAN port?), and then the switch to a LAN port, will that preserve 2.5 gig throughput for all?
Thanks again -- Chuck
CrimpOn
Dec 09, 2024Guru - Experienced User
- Chuck_MDec 09, 2024Mentor
This is the answer! My pfSense box is 2.5 gig.
Thank you for taking the time to explain the finer details to me... greatly appreciate it -- hope to be able to return the favor one day.
Will let you know how it turns out and what the resultant behavior is.
Chuck
