Deeprater6ll
Apr 09, 2024Aspirant
Ap mode
I have my orbi in ap mode but the host device has no firewall capability. How can I get a firewall set up as the orbi in ap mode doesn't utilize a firewall
Deeprater6ll
There us a dmz tab. Do I put in the ip or just mark the tab? .I don't mean to sound like an idiot.i do appreciate your help.thank you
Apr 09, 2024Guru - Experienced User
Not sure how to enable DMZ on that host router. Something to ask T-Mobile about. I presume if you check the box, would enabled it then you'll need to input an IP address there. This would be the IP address the RBR is getting from the host router.
- Deeprater6llApr 09, 2024AspirantI have an orbi router in ap mode with my tmobile internet gateway5g.the host has no firewall capability. I have an ethernet cable connected to both. I also have an ethernet attached from the orbi to my desktop computer. Do I need to be concerned about not having a firewall on the the two devices or am I safe with the firewall on the computer
