gte534j
Sep 29, 2025Star
Attached Devices list shows for about a day then is not available on web app for RBE871
Hi, The Attached Devices list shows for about a day then is not available on web app for RBE871. I do a reboot then the attached devices show again for about a day. Router RBE871 V10.5.20.4_1...
Sep 30, 2025Guru - Experienced User
gte534j wrote:The Attached Devices list shows for about a day then is not available on web app for RBE871. I do a reboot then the attached devices show again for about a day.
I see that with my own 870 - though with my system it takes longer for the problem to surface. Like you the only way I've found to fix it is to reboot. Which is quite annoying.
I did try reporting the issue, but so far just crickets...
I'm not seeing this at the moment, and I guess it's possible that the 10.5.20.4 has changed the behavior.
