gte534j
Sep 29, 2025Star
Attached Devices list shows for about a day then is not available on web app for RBE871
Hi, The Attached Devices list shows for about a day then is not available on web app for RBE871. I do a reboot then the attached devices show again for about a day. Router RBE871 V10.5.20.4_1...
gte534j
Dec 09, 2025Star
Nope- still not working. This was not working prior to adding in the satellites. I did just reboot my router and its working for now but that normally just lasts a few hours-
- FURRYe38Dec 09, 2025Guru - Experienced User
Have you submitted a support ticket with NG regarding this?
What browser are you using?
- StephenBDec 10, 2025Guru - Experienced User
I saw this for several months with my own 870 system, but haven't seen it recently. The router's been up for about 15 days...
Do you have access control turned on? I saw lots of devices missing from the attached device list when I had it turned on (even with "allow all new devices to connect"). The devices seemed connected anyway, but were missing from the list.
So if you use that, try turning it off as a test, and see if the problem resolves.
- gte534jDec 12, 2025Star
So its been 4 days and seems like the problem has resolved itself somehow. Not sure exactly how, but the attached device list shows on the web page and on the app, and they match and are correct.
- FURRYe38Dec 12, 2025Guru - Experienced User
If this happens again, let us know. I would try the system with out the 770 RBS.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemEnjoy. 📡
