gte534j
Sep 29, 2025Star
Attached Devices list shows for about a day then is not available on web app for RBE871
Hi, The Attached Devices list shows for about a day then is not available on web app for RBE871. I do a reboot then the attached devices show again for about a day. Router RBE871 V10.5.20.4_1...
Dec 10, 2025Guru - Experienced User
gte534j wrote:Nope- still not working. This was not working prior to adding in the satellites. I did just reboot my router and its working for now but that normally just lasts a few hours-
I saw this for several months with my own 870 system, but haven't seen it recently. The router's been up for about 15 days...
Do you have access control turned on? I saw lots of devices missing from the attached device list when I had it turned on (even with "allow all new devices to connect"). The devices seemed connected anyway, but were missing from the list.
So if you use that, try turning it off as a test, and see if the problem resolves.
gte534j
Dec 12, 2025Star
So its been 4 days and seems like the problem has resolved itself somehow. Not sure exactly how, but the attached device list shows on the web page and on the app, and they match and are correct.
- FURRYe38Dec 12, 2025Guru - Experienced User
If this happens again, let us know. I would try the system with out the 770 RBS.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemEnjoy. 📡
