YourMainDude
Nov 04, 2023Apprentice
Auto Config and Auto Detect do not maintain continued ipv6 addressing
I had forgotten how badly Orbi routers were with respect to maintaining ipv6 connectivity. I wish I had remembered this before spending THIS AMOUNT of money for the new WiFi 7 kit.
Auto Config...
Nov 07, 2023Guru - Experienced User
Not the first time the ISP would be involved in the IPv6 issues seen.
YourMainDude
Nov 07, 2023Apprentice
If I throw my Velop 6E router node back into position IPv6 is consistently maintained. That doesn't completely dissolve Xfinity from playing a role but considering how big of a provider they (Comcast) are, I would expect Netgear - also being preeminent - to have this stuff figured out by now - no matter the ISP handshaking going on.
- FURRYe38Nov 07, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Does configuring 6to4 or Static work?
- YourMainDudeNov 07, 2023Apprentice
It's a Netgear modem - CM2000.
I'm working it with other help. No time for shot-gun helpers...
Good Luck then.
I've asked others in a different area with the 970 series and this ISP. None has returned mentioning having problems with Auto Config or Detect failing on there systems.
