tjscales's avatar
tjscales
Follower
Mar 03, 2026
Backhaul 1 gb not 2.5gb
I have an 870 system. One satellite. When I connect the satellite to my switch, it connects at 1gb. The switch and my network is 2.5gb.
The ports are all supposed to be 2.5gb but I am not seeing that.
Any ideas?
  • StephenB's avatar
    How far is the satellite from the switch?
    Is it practical to try another cable?
  • CrimpOn's avatar
    CrimpOn
    This is correct.  All the Ethernet ports on the 871 router and 870 satellite are combination 2.5GB/1.0GB/100Mb ports.  They are supposed to autonegotiate the correct speed when connected to another Ethernet device. https://en.wikipedia.org/wiki/Autonegotiation
    What is the brand/model of the 2.5GB switch?
    How are you informed that the satellite has connected at 1GB rather than 2.5GB?
    (does this information come from the switch? the satellite? the router?)
    If the satellite is temporarily relocated to the same room as the router and connected with an Ethernet cable (i.e. no switch), what happens?
