Anderson_lien
May 03, 2025Aspirant
BRE971 router with 2 RBE970 satellites sync problem
When I opened box (one router and 2 satellites) and try to install my Orbi RBE973S, it prompt me to update the firmware, I pressed "OK", but after that I found one of my satellite can not be sync., t...
May 03, 2025Guru - Experienced User
Did you try to ethernet connect the RBS to the RBR and see if it would updated there?
Does it get a IP address if you ethernet connect it to the RBR?
Did you review the PDF file to see if you can access the RBS web page to manually update it?
Anderson_lien wrote:
Thank you, but the firmware manual update page doesn't show the bad satellite, I have no check box to be checked, I am unable to update it manually.
Mikey94025
May 03, 2025Hero
FURRYe38 wrote:Did you review the PDF file to see if you can access the RBS web page to manually update it?
Anderson_lien wrote:Thank you, but the firmware manual update page doesn't show the bad satellite, I have no check box to be checked, I am unable to update it manually.
Here's more detail on this method. If your satellite gets an IP address and you can reach it from a desktop browser, then use its admin website to update the firmware (after downloading it from Netgear's support website). For example, one of my satellites has the IP address 192.168.2.73. I can reach its admin website at http://192.168.2.73/ . On the left I can click Firmware Update to manually update its firmware. Attached is a browser screenshot accessing my satellite's admin website.
- Anderson_lienMay 10, 2025Aspirant
Can not see satellite , no way to get IP or update. Thank you!
