Stallion69
Dec 01, 2024Tutor
Buffering Issues
I replaced my ORBI RBR50 mesh system with ORBI 970 Series WiFi 7. When playing or streaming videos, it keeps buffering and I have to turn WiFi off and switch back to 5G Network. It's annoying. Not...
- Dec 04, 2024Hello Stallion69,
I understand that you are having issues with your RBE971 with video streaming. We have a new firmware for the North American region that may resolve this issue. At your earliest convenience, please upgrade to firmware version 9.12.4.16. Please be sure to upgrade the firmware on the attached satellites before the router.
Firmware Version 9.12.4.16 for RBE970/971 download link:
https://kb.netgear.com/000066418/RBE970-RBE971-FiOrbi rmware-Version-9-12-4-16-for-NA-Region-Only
Please visit the link below for step-by-step instructions on upgrading the firmware on your Orbi Mesh System:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
Best,
Kevin
Community Team
Stallion69
Dec 01, 2024Tutor
Answers below:
What Firmware version is currently loaded? (v9.12.3.3)
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? (Hitron is the modem provided form Cogeco. Model Name: CODA-4589)
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended. (Cat 6A and above being used)
How many RBS are deployed? (2 Satellites and they are wired back to Orbi Router_Back Haul)
What is the size of your home? (2500 Sq Ft?)
What is the distance between the router (30-40ft)
Does this happen with the RBS turned OFF? (No)
Does this happen with both wireless and wired devices? (Yes)
What channel configurations are currently set on the router? ???
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...
Armor, Smart Parental Controls or Circle, Protection Engine, Traffic Meter. (All those are disabled already)
Dec 04, 2024Guru - Experienced User
Stallion69 wrote:
Answers below:
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? (Hitron is the modem provided form Cogeco. Model Name: CODA-4589)Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
What is the size of your home? (2500 Sq Ft?)What is the distance between the router (30-40ft)
For this size of home, only the RBR unit and just one RBS would be needed. Having two RBS deployed maybe causing problems. Lets turn OFF one RBS for now.
Too Much Wifi: https://youtu.be/UR0viMLISz4
Does this happen with the RBS turned OFF? (No) Lets turn OFF one RBS for now.
