Bmog1213
Mar 02, 2026Aspirant
Can’t generate device list after 12 hours post reboot
Same issue here , can’t generate device list after 12 hours post reboot !!! App recognizes the satellite however lots of devices including tp link light switches seems offline even though I clearly c...
Mar 03, 2026Guru - Experienced User
Yes is a known issue and is being worked on. NG IS aware of it. Orbi App should be working. It's the WEB UI that is failing. Were all waiting on NG to release the fix. No idea of when that will be. Something you can contact NG support about.
Failing on mine as well.
