Yld2rob
Nov 22, 2023Luminary
Can someone install the new firmware
Can someone install the new firmware and let me know if this fixes the random device drop issues. If so, I will run out and re-purchase it.
JustinThyme
Dec 01, 2023Guide
I’ve not had any dropped connections period. Only issue I’m having is can’t use a wired backhaul through a managed switch. Engineering acknowledged this in the post I made and said they knew about it and it’s on the list for next FW update. The previous 960 used the wired backhaul on one satellite upstairs using the same switch. I literally just unplugged the 960 and plugged in 970 with exact same wires and exact same configuration. MLO doesn’t want to work right and would be nice to have but for now it’s off. I can see every device connected to the router except the one satellite. It tries to come up, light turns blue then it just stays at configuring so it has a connection to router through switch, just doesn’t configure and become useable on wired backhaul. Unplug it and reset everything and it works fine wirelessly. New tech so expect a few bumps for an early adopter. They still have some work to do on FW not only for issues mentioned but a bit more control for 6GHz especially. Also no wireless diagnostics tool like 960 so you could make the best choice for wireless Channels.
