Ludo78
Jun 18, 2024Aspirant
Can we extend Orbi 960 network with 970 satellite?
Hi, I have invested into an Orbi 960 system a year ago (1 router + 3 satellites) I need to extend my network to an office in my garden, where i have pulled an internet cable from my house (a cab...
CrimpOn
Jun 18, 2024Guru - Experienced User
Ludo78 wrote:
I need to extend my network to an office in my garden, where i have pulled an internet cable from my house (a cable because it is too far away to have a good signal, like 40 meters and 2 big walls)
This situation may be suitable for a different solution: a simple WiFi access point (AP).or router which supports AP mode. For example, a Netgear R6700AX (or similar router from other vendors) sells for under $100 on Amazon. The R6700AX provides WiFi6 and four gigabit Ethernet ports for devices like desktop computers, printers, NAS devices, etc.
Mesh WiFi systems were created for one specific purpose: seamless roaming for mobile devices. The only devices likely to "roam" between the office location and the main house are phones, tablets, and laptops. 40 meters and two thick walls may result in mobile devices losing their WiFi connection to the house by the time they enter the office (or vice versa). In that case, they will simply reconnect and the user will be blissfully unaware that anything has happened. Otherwise, turn WiFi off and back on again, and "voila!"
I want to be clear that the "A" solution is a 960 satellite selling for $600 on Amazon. Just want to point out that this situation is a bit unique.
