JCasto
Feb 23, 2024Initiate
Carrier Infinity Touch wall controls will not connect.
The Orbi 960 has the exact same problem. Carrier Infinity Touch wall controls will not connect.
- Feb 21, 2025
Success!!! Woo Hoo!!!
I've been working with Matt, a level 2 Netgear Engineer over the past couple of weeks. He has been fantastic. He had me send some log files over and they sent me new firmware a few days later. I applied it and still couldn't connect. Same issue. Matt had me send over additional log files after the first firmware was applied. Last night he sent me new firmware and I applied it this morning. I am now able to connect my Carrier Infinity Touch thermostat to the Obri RBE 771/770 network!
Thanks for all of your support and ideas! So glad this is resolved and hopefully it will help others.
Rallye455
Jan 25, 2025Guide
This is completely unacceptable. I have spent hours troubleshooting. I am going to escalate my case: 48815294
- CrimpOnJan 25, 2025Guru - Experienced User
This conversation appears to be incomplete. Would it be convenient to comment on the current problem (and system) in more detail:
- Which specific model of Carrier Infinity Touch?
- Which specific model & firmware of Orbi?
- Is the process in this video what is failing?
https://www.google.com/search?client=opera&q=Carrier+Infinity+Touch&sourceid=opera&ie=UTF-8&oe=UTF-8#fpstate=ive&vld=cid:ec262452,vid:5Kg5rKG7QaY,st:2
- Rallye455Jan 27, 2025Guide
- Which specific model of Carrier Infinity Touch? Model SYSTXCCITC01-A
Hardware Version RBE771 Firmware Version V10.5.13.1_2.2.34 GUI Language Version V4.0.0.22_2.1.30.3 - Is the process in this video what is failing? Yes. It will not connect. It worked fine on all routers until this Orbi RBE771 which is WiFi 7. Last router it worked on is a Nighthawk WiFi 6.
https://www.google.com/search?client=opera&q=Carrier+Infinity+Touch&sourceid=opera&ie=UTF-8&oe= - Also, I have tried all permutations known. I have also set up a SSID that is IoT, and using only 2.4Ghz.
- IPv6 is disabled.
I appreciate any help. This is clearly a Netgear issue, not a Carrier issue.
- FURRYe38Jan 27, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Does this happen with the RBS turned OFF?
What channels are you using on the RBR?
If you turn OFF the RBS and then set the WiFI security on the IoT network to NONE or OPEN, does the device connect to RBR at all? Re-enabled WiFi security after checking this. Turn on the RBS afterwards.
- IPv6 is disabled.
