JCasto
Feb 23, 2024Initiate
Carrier Infinity Touch wall controls will not connect.
The Orbi 960 has the exact same problem. Carrier Infinity Touch wall controls will not connect.
- Feb 21, 2025
Success!!! Woo Hoo!!!
I've been working with Matt, a level 2 Netgear Engineer over the past couple of weeks. He has been fantastic. He had me send some log files over and they sent me new firmware a few days later. I applied it and still couldn't connect. Same issue. Matt had me send over additional log files after the first firmware was applied. Last night he sent me new firmware and I applied it this morning. I am now able to connect my Carrier Infinity Touch thermostat to the Obri RBE 771/770 network!
Thanks for all of your support and ideas! So glad this is resolved and hopefully it will help others.
Rallye455
Jan 31, 2025Guide
FYI - Last night the Level 2 engineer emailed me to ask for the following, which I promptly provided:
1. Network diagram/Topology:
-What is the modem brand and model?
-Is the main Orbi router connected to the modem?
-Is there any other networking device aside from the modem and Orbi router/satellite?
ex. modem (brand/model) -> switch/firewall (brand and model if there is any) -> Orbi router -> Orbi satellites (how are the satellites connected (wired or /wireless))
2. Config file.
This is how to get the config file:
-Please provide the admin password so that we can locally access the config file
3. Copy of router logs:
-Go to orbilogin.com
-Go to Advanced page
-Go to Administration -> Router logs
Rallye455
Feb 21, 2025Guide
- CrimpOnFeb 21, 2025Guru - Experienced User
Thanks for reporting the resolution. He probably gave no indication of what was causing the problem? (only: "Here. Try another firmware version.")
- FightgarApr 06, 2025AspirantI am having the same issue with my new RBE871. Can someone share what they did to get the router to work with thee Carrier Infinity thermostat? Where can I get the firmware you used?
- FURRYe38Apr 07, 2025Guru - Experienced User
Please make contact with NG support and open a support ticket. I'd post a link to this thread for reference.
Good Luck.
