Acidreign
Oct 06, 2024Follower
Changing to wired backhaul on RBE971
Hi there, I previously setup the Orbi 970 satellite on wireless and would like to change the configuration to a wired backhaul. Is there a quick way to do this or do I need to do a setup from scratch?
Oct 06, 2024Guru - Experienced User
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡 ‌‌🛰
Be sure your using good quality LAN cable. CAT6A STP is recommended. ️
