MitchLittle
Oct 28, 2024Aspirant
CM3000 and Sparklight
Can I replace my current Sparklight modem with a CM3000 and full Orbi970 system and keep all of the SSID and passwords the same as my current system so that I do not have to update all of the endpoin...
Oct 28, 2024Guru - Experienced User
Yes.
I'm on SL as well and currently have my CM3000 connected to my 970 series system.
Be sure to check with the ISP as well on any additional requirements that you may have. If you have phone for voice support then the CM3000 won't work. Otherwise, will be fine to use. You can use same SSID name and password from current system on the Orbi system.
- MitchLittleOct 28, 2024Aspirant
do you disconnect the old modem, then power up the new one before you call SL tech?
- FURRYe38Oct 28, 2024Guru - Experienced User
Yes.
- MitchLittleOct 29, 2024Aspirant
I will have my CM3000 and Orbi 970 tomorrow and will get started. As I understand it... I will...
power up the CM3000, and connect it to the in coming coax
connect Sparklight tech to get them to connect the new modem
Do I power up the full Orbit system and connect it to the modem, or just the base unit.
Do I set up the Orbit system from the app?
How do I reuse the old SSID and passwords?
Thanks for the help
Mitch
