muhvieira
Apr 28, 2024Aspirant
Configure modem for 1000 Mbps speed(Xfinity)
I’m having issues with my speed connection and Xfinity told me I need to configure my modem to be able use my 1000 Mbps speed. How do I do it? My modem model is a NETGEAR Nighthawk Modem WiFi Router Combo C7000-Compatible with Cable Providers Including Xfinity by Comcast, Spectrum, Cox for Plans Up to 800Mbps | AC1900 WiFi Speed | DOCSIS 3.0.
Thank you
D3.0 wasn't supported for 1Gb on some iSPs. If you want 1Gb ISP speeds, you'll need a D3.1 supporting modem.
Someting to contact about and check to see what is supported. NETGEAR CM series cable modems are mostly D3.1 supporting. Last C series gateway modem was the C7800 I believe.
- muhvieiraAspirant
Thank you so much for replying back to me, which speed would be the max that my modem would accept?
