muhvieira
Apr 28, 2024Aspirant
Configure modem for 1000 Mbps speed(Xfinity)
I’m having issues with my speed connection and Xfinity told me I need to configure my modem to be able use my 1000 Mbps speed. How do I do it? My modem model is a NETGEAR Nighthawk Modem WiFi Router ...
Apr 28, 2024Guru - Experienced User
What ever the next lower speed package the ISP supports for your model modem. Ask them about this.
Good Luck.
muhvieira wrote:
Thank you so much for replying back to me, which speed would be the max that my modem would accept?
Apr 29, 2024Guru - Experienced User
The C7000v2 is only supported for up to 863mbps.
Is it worth trying to get the extra 100mbps by upgrading your modem/router?
Thats up to you.
If you did, I'd try for a device that supports their mid split speeds and get a router separate. More expensive but if you're going to pay for that extra 100mpbs, you m right as well pay for mid split to get the increased upload to.
Or you can keep using your device as you really won't see a performance difference from 863mbps to 963 mpbs
