icebeam
Nov 29, 2023Guide
Daily Disconnects from IoT Network
Hi All, I am running an Orbi 970 system with firmware version V9.10.2.3_1.1.13 on both the router and the two satellites. Prior to the 970 system, I had the Orbi 960 system, and that worked flawl...
Dec 19, 2023Guru - Experienced User
Any progress on this?
Might update if you see this, if you haven't already:
