Seanmh72
Jun 03, 2024Aspirant
Devices appear on blocked list
Starting this afternoon, several devices have begun to appear on my Access List as being blocked. I am able to take them off, but there does not seem to be a rhyme or reason for it and I do not s...
Jun 03, 2024Guru - Experienced User
What devices are these?
What NG product are you using?
Not much to go on here.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Seanmh72
Apologies, it didn’t keep the product. This is the NG WIFI 7 Mesh RBE971.
Devices don’t matter. I had my work laptop (HP/Windows), iPhone, iPad, DirecTV Stream device and a couple smart plugs, plus a couple more.
I haven’t updated/changed anything with access control since I set the device up earlier this year.
- FURRYe38Jun 03, 2024Guru - Experienced User
