freefyre
Oct 18, 2023Follower
Disable SSID broadcasting on Orbi 970
Hello! I am considering a purchase of this for a business. However, I need to turn off SSID Broadcasting. Is this possible on this model?
schumaku
Oct 20, 2023Guru - Experienced User
No idea where my previous reply went to: No, a hidden SSID does just add security by obscurity. Poking a so-called hidden (NUL string) SSID does nicely return the correct ESSID when polled. Ask Dr. Google if you don' trust the old grey haired people here ...
CrimpOn
I believe an option to not broadcast the SSID was a common feature of early WiFi systems. Netgear included this option on the RBS50, and it remains available on the current firmware release:
The option was removed when AX systems came out. "Times Change".
