EntropyDF
Aug 14, 2024Aspirant
Disable Wireless Backhaul (RTGRBH_ Network)
I have an RBE771 with with two satellites connected via Ethernet. Everything is working pretty well, no large issues or concerns. Hardware Version RBE771 Firmware Version V10.5.6.5_2.2.2...
Aug 14, 2024Guru - Experienced User
You can't disable it.
and it changes channels because there isn't a dedicated backhaul like the other versions.
