andej's avatar
andej
Does forgetting network and reconnecting do anything ?
I purchased the new Orbi Wifi 7 system and initially renamed the SSID to my previous network to save the effort of moving a lot of devices over.
I am experiencing some poor reliability with this system compared my previous system that cost 1/10hth the price.
However, i'm wondering if the process of "forgetting the network" and then reconnecting to it do anything different than if I just allowed the existing devices automatically connect to the old SSID name ?
  • CrimpOn's avatar
    CrimpOn
    As long as the WiFi credentials are exactly the same, there is no need to (or benefit from) "forget" the connection.
  • plemans's avatar
    What system did you have?
    What firmware version is on the router and the satellite currently?
    What modem/gateway is it connected to?
    How big is your home? the newer 7 systems have a bit more coverage and you can have to much coverage at times
