GerardN
Apr 02, 2024Aspirant
Does the Oribi 970 support DHCP Option 61
Hi, im considering purchasing the Orbi 970 system to work with my Sky broadband in the UK. I understand it can only work with sky broadband is DHCP option 61 is supported by the router - can anyone p...
Apr 02, 2024Guru - Experienced User
I see it appeared on the 750/850 series:
I haven't looked at mine lately as I normally don't use this feature. I'll check again later today and confirm for the 970 series to be sure.
I know that KB needs to be updated as well to reflect other models that support this feature.
- GerardNApr 02, 2024Aspirant
Hi Furry- it would be great if you could confirm that one for me. Appreciate it
Cheers
- FURRYe38Apr 02, 2024Guru - Experienced User
Will do...
Excellent - this is helpful, thanks a lot. Will order shortly!
- MightyAtomJul 31, 2025Guide
Hi FURRYe38, about to get the 970 also next week can you confirm exactlt what page you are looking at for teh settings and also what exactly goes in teh two boxes and if there are any other additions i need to adjust. Cheers buddy.
