GerardN
Apr 02, 2024Aspirant
Does the Oribi 970 support DHCP Option 61
Hi, im considering purchasing the Orbi 970 system to work with my Sky broadband in the UK. I understand it can only work with sky broadband is DHCP option 61 is supported by the router - can anyone p...
GerardN
Hi Furry- it would be great if you could confirm that one for me. Appreciate it
Cheers
- GerardNApr 02, 2024Aspirant
Excellent - this is helpful, thanks a lot. Will order shortly!
- FURRYe38Apr 03, 2024Guru - Experienced User
đź›’
- MightyAtomJul 31, 2025Guide
Hi FURRYe38​, about to get the 970 also next week can you confirm exactlt what page you are looking at for teh settings and also what exactly goes in teh two boxes and if there are any other additions i need to adjust. Cheers buddy.
- FURRYe38Jul 31, 2025Guru - Experienced User
Advanced tab/Setup/Internet
