GerardN
Apr 02, 2024Aspirant
Does the Oribi 970 support DHCP Option 61
Hi, im considering purchasing the Orbi 970 system to work with my Sky broadband in the UK. I understand it can only work with sky broadband is DHCP option 61 is supported by the router - can anyone p...
MightyAtom
Jul 31, 2025Guide
Hi FURRYe38, about to get the 970 also next week can you confirm exactlt what page you are looking at for teh settings and also what exactly goes in teh two boxes and if there are any other additions i need to adjust. Cheers buddy.
- FURRYe38Jul 31, 2025Guru - Experienced User
Advanced tab/Setup/Internet
