pierreha's avatar
pierreha
Even after the latest update, i m still facing the same issue
even after the latest update, i m still facing the same issue, i had high expectation and now i m back using 7years old Router than works way better. please any solution
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    Does the front LED on the RBR turn RED/Pink when this happens?
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn off router, RBS and computers.
    Turn on the router and wait 2 minutes for it to connect. Power ON the RBS.
    Turn on computers and rest of network.
    • pierreha's avatar
      pierreha
      What Firmware version is currently loaded? Vers. 9.11.0.1
      What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Netgear Nighthawk CM2000
      Be sure you're using a good quality LAN cable between the modem and router. CAT6A STP is recommended. Yes I have CAT 7
      Does the front LED on the RBR turn RED/Pink when this happens? I never paid attention when it happen to the LED lights
      Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update? No I haven't
      Has a factory reset and setup from scratch been performed since last FW update? no I didn't reset to default since FW update, it would be crazy to me that much expensive router I need to reset it after each update, I had mesh links's for 7 years, it use to update and run with no issue. I m sorry it is just frustrating
      • FURRYe38's avatar
        Please post a copy and paste of the modems connection status and event log page.
        https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
        https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
        Make sure the CAT cable is STP and not UTP.
        Please observe for this for next time.
        Please try this at your earliest convenience.
        Understand, however a factory reset maybe needed. However lets try the above suggestions first, this as a last resort.
