ApexWifi
Jan 09, 2024Tutor
Experiencing disconnects and slow loading on iPhone 14's
When will the new firmware be released...? Experiencing disconnects and slow loading on iPhone 14's.
ApexWifi
Oct 23, 2024Tutor
Making everyone aware...
Everything was working perfectly fine prior to this update. Experiencing several wifi disconnects throughout the day from several devices: iPhone, iPad, Thermostat, etc.
Apparently, there is a bug in this firmware so please don't send me the generic troubleshooting steps. Nothing in my environment has changed.
- CrimpOnOct 23, 2024Guru - Experienced User
If you decide to manually install the previous firmware to achieve stability, please remember:
- There are specific firmware versions for Asia Pacific, Europe, and US.
- With AX systems, it is essential to load firmware on satellites before loading on the router.
- To prevent the system from automatically updating firmware immediately after it restarts, it is a good idea to disconnect the router from the internet during the firmware installation process. After everything comes up, check that the "Automatic Firmware Update" option is set to Disable before connecting to the internet.
