JPerkinski
Dec 21, 2023Aspirant
Firmware V9.10.4.1_1.1.17 killed satellites
I have an Orbi 970 and two satellites. Today I did the usual firmware update I have been doing every few weeks which normally goes fine but today, after the firmware update my two satellites never re...
Dec 21, 2023Guru - Experienced User
Try ethernet connecting the RBS to the RBR?
What is the distance between the router and 📡 satellite(s)?
JPerkinski
Thanks for the reply. Connecting the main router to the satellites via Ethernet is not an option right now.
The house is small. I can't give numbers but it's not a large house and until today, everything worked great.
I've done a handful of updates since getting this unit and the two satellites and today's update is the first time there has been an issue.
- FURRYe38Dec 21, 2023Guru - Experienced User
As a quick test you can take one of the RBS and ethernet connect it to the back of the RBR and see if it updated.
Do you know what version of FW that was on the system prior?
If you can get the home size in sq ft will be helpful. Too small of a home, may only need one RBS vs two.
- JPerkinskiDec 21, 2023Aspirant
Tomorrow I can connect one of the satellites via Ethernet to see what happens.
Are there any tips or things I should look for once the satellite is hard-wired to the main router?- FURRYe38Dec 21, 2023Guru - Experienced User
If it will connect, might try the FW update utility on the RBR under Administration and see if it will see the RBS and update it.
Ya first time seeing someone post about there RBS not working or being updated after the RBR. RBS are supposed to be updated. Straq
Please let us know the home size and distances between the RBR and RBS.
