Validus
Sep 19, 2023Luminary
For the Quad-Band...
For the Quad-Band, is one of those Wifi channels dedicated for the back haul communication only, shared or a toggled option? What would the distance be for that, Router to Satellites?
I assume ...
xyz123456789zg
Oct 02, 2023Aspirant
6GHz3 (4x4/320MHz, 4K-QAM): 11,530Mbps
5GHz-1 (4x4/240MHx, 4K-QAM): 8,647Mbps, Dedicated Backhaul
5GHz-2 (4x4/160MHz, 4K-QAM): 5,765Mbps
2.4GHz (4x4/40MHz, 1K-QAM): 1,147Mbps
It means that we couldn't use 5G1? 240mhz couldn't be used on the user?
Oct 03, 2023Guru - Experienced User
5GHz-1 (4x4/240MHx, 4K-QAM): 8,647Mbps, Dedicated Backhaul < Means not usable by users or configurable.
No.
- xyz123456789zgOct 03, 2023AspirantIs 5G2 support 2*2 160mhz? 5G1 couldn't be used by user, can we choose 36-48 channel on 5G2?
- FURRYe38Oct 03, 2023Guru - Experienced User
Most 2x2 devices only support up to 80Mhz. 4x4 devices support 160Mhz.
Yes.
- xyz123456789zgOct 03, 2023AspirantMost Android mobile are support 2*2 160mhz@5G, maximum link is 2882mbps. RBE972 - 5GHz-2 (4x4/160MHz, 4K-QAM): 5,765Mbps, I would like to know whether it is support 2*2 support 2882mbps for mobile? If it is same as RBKE962, only support 80mhz@5G, that would be a shame.
