icebeam
Jan 05, 2024Guide
Found Fix To IoT Disconnect Issues
Hi All, I've been experiencing daily disconnections on the Orbi 970 IoT network while using the "2.4 GHz only" mode. However, after switching to the "2.4 GHz and 5 GHz" mode, these disconnections ...
Jan 06, 2024Guru - Experienced User
So having the IoT network only configured for 2.4Ghz was causing disconnections for the connected devices, then enabling both 2.4 and 5Ghz configuration on the IoT network seems to have stopped the disconnections?
icebeam
Jan 07, 2024Guide
Correct. My connection has been stable for a week with no disconnects, whereas previously I would experience them daily, particularly with devices like Nest, 2.4GHz-only Ring cameras, and other 2.4GHz-only devices. This improvement has been a significant relief.
- FURRYe38Jan 07, 2024Guru - Experienced User
How many devices did you have all contacted at one time while using only the 2.4Ghz radio for the IOT network?
- icebeamJan 07, 2024Guide
44 devices connected.
Are any of these 44 devices 5Ghz supporting?
Possible that having that many on the 2.4Ghz could be causing it to over load and destabilize. Seems that since you enabled 5Ghz that some of these off loaded to 5Ghz and whats left on 2.4Ghz is stabilized.
