icebeam
Jan 05, 2024Guide
Found Fix To IoT Disconnect Issues
Hi All, I've been experiencing daily disconnections on the Orbi 970 IoT network while using the "2.4 GHz only" mode. However, after switching to the "2.4 GHz and 5 GHz" mode, these disconnections ...
icebeam
Jan 07, 2024Guide
Please help me understand something. Do I even need the IoT network?
Does the ferrari network only do 5Ghz and 6Ghz? so the IoT (i3 network) is needed for 2.4ghz devices.
Also do you think there is a speed difference between ferrari and i3 5Ghz networks if the device does not support 6GHZ? Like should I move my 2.4Ghz/5Ghz capable devices over to Ferrari to get a speed increase...
Jan 08, 2024Guru - Experienced User
All three frequencies are supported on the main WLAN network.
The IoT network is there for users to use for IoT devices and specifically for 2.4Ghz devices that historically had problems connecting to Older Orbi systems that didn't have this feature.
Kinda need to test things out as you see fit and see what works best for you. I presume if you have lots of just IoT devices that don't need fast speed or performance, put them on the IoT network and save the main WLAN for devices that need good speed and performances.
