nakiri
Nov 30, 2023Guide
FW 9.10.1.3001 -> 9.10.2.3 update path, FYI
For whatever reason the .3001 version (which has the Pixel 8 Pro hotfix), has worked fine for two weeks, but today couldn't keep the satellites up on either wired or wireless backhaul. Constantly cyc...
Nov 30, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
