pmhiii
Oct 21, 2024Aspirant
Google apps will not load without a VPN
We have a RBR750 mesh router with one satellite connected to a Comcast cable modem on windows 10. We are unable to load any Google application without the use of a VPN. This is especially impactful...
CrimpOn
Oct 21, 2024Guru - Experienced User
I, also, have an RBR750 router and satellite on the current firmware release v7.2.6.31 and a Windows 11 laptop (no VPN)
Please identify which Google Apps will not install and I will try them.
- pmhiiiOct 21, 2024Aspirant
I can get the Google website and GMail to load. All the other apps from the Google home page fail to load without a VPN
- CrimpOnOct 21, 2024Guru - Experienced User
Are these all web sites, accessed with a browser, such as:
All of these web sites open for me in Edge, Firefox, Chrome, and Opera on Windows, when connected to both an RBR50 system and to an RBR750 system.
I use the Android GMail 'app' on a smartphone. two different Android tablets, and one Chromebook.
Can you post a screen shot of the error message that suggests a VPN is required?
Attached is a screenshot. There's no suggestion of a VPN. That's the only sollution I have found to work. I've reset the router to factory without success.
