AbbasRaza
Dec 14, 2023Guide
Guest Network Issue
So when I had first purchased the orbi 970 (2 pack) which comes with one router and one satellite. I followed the instructions just like every other routers i had in the past and installed both the r...
- Dec 26, 2023
So after couple of days with having both the router and the satallite on wired backhaul, I can finally say that the guest network is working flawlessly after this new firmware update. The only one issue that I am still having on my pixel 8 pro is that sometimes just randomly I get a no internet connection message on my phone. I then have to go into my wifi settings and click on my primary SSID and click on disconnect and then click on reconnect and then it works. I notice it happens a lot when ever I leave the router and get connected on the satallite or vice versa and I get that same error message that I have no internet and that's when I do that same steps in order to gain wifi access.
Dec 14, 2023Guru - Experienced User
- AbbasRazaDec 14, 2023GuideFirmware V9.10.2.3.
- FURRYe38Dec 14, 2023Guru - Experienced User
I don't think the Pixel issue is in this version of FW.
I believe there is a beta that's available that you can send a PM to Straq to get ahold of.- AbbasRazaDec 14, 2023GuideIt's not a pixel issues. It's a guest network issue. This is the firmware I received from straq.
