AbbasRaza
Dec 14, 2023Guide
Guest Network Issue
So when I had first purchased the orbi 970 (2 pack) which comes with one router and one satellite. I followed the instructions just like every other routers i had in the past and installed both the r...
- Dec 26, 2023
So after couple of days with having both the router and the satallite on wired backhaul, I can finally say that the guest network is working flawlessly after this new firmware update. The only one issue that I am still having on my pixel 8 pro is that sometimes just randomly I get a no internet connection message on my phone. I then have to go into my wifi settings and click on my primary SSID and click on disconnect and then click on reconnect and then it works. I notice it happens a lot when ever I leave the router and get connected on the satallite or vice versa and I get that same error message that I have no internet and that's when I do that same steps in order to gain wifi access.
AbbasRaza
Dec 14, 2023Guide
Firmware V9.10.2.3.
Dec 14, 2023Guru - Experienced User
I don't think the Pixel issue is in this version of FW.
I believe there is a beta that's available that you can send a PM to Straq to get ahold of.
- AbbasRazaDec 14, 2023GuideIt's not a pixel issues. It's a guest network issue. This is the firmware I received from straq.
- FURRYe38Dec 14, 2023Guru - Experienced User
If you connect the RBS wirelessly to the RBR does same problem happen?
His is the one RBS connected to the RBR? Directly behind the RBR or is there a LAN switch in between or a patch panel?
Which port are you using on the RBR to connect the RBS?
What CAT# LAN cable is being used between them?
What security mode are you setting on the Guest Network?
- AbbasRazaDec 14, 2023GuideI have tired using it wirelessly as well but same issue. Both are connected via a cat 7 cable. On the router end it is connected on the 10gig port and the other end on the 10 gig port satallite
