CaptiveBolt
Jan 26, 2024Aspirant
Have you ever heard of this issue?
Furry,
https://discussions.apple.com/thread/8150492?sortBy=best
I wonder how many people, me being one, have Apple TVs on their networks.
- Mar 22, 2024
Glad the RMA fixed it. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Feb 03, 2024Guru - Experienced User
Are you RBS ethernet connected or wireless?
If ethernet connected, direct connected to the RBR or is there a LAN switch in between the RBR and RBS? If so, Brand and model please...
CaptiveBolt
Feb 03, 2024Aspirant
They’re both hardwired and reading as good
- FURRYe38Feb 03, 2024Guru - Experienced User
Direct connected to the RBR or is there a LAN switch in between the RBR and RBS? If so, Brand and model please...
- CaptiveBoltFeb 03, 2024AspirantHey Furry- they’re both running through a tp link 10 gig unmanaged non poe switch.
AH ok. Good. Model of this switch please.
I'm getting some info that NG is investigating this issue when RBS are ethernet connected to a 10Gb non managed switch.
