CaptiveBolt
Jan 26, 2024Aspirant
Have you ever heard of this issue?
Furry,
https://discussions.apple.com/thread/8150492?sortBy=best
I wonder how many people, me being one, have Apple TVs on their networks.
- Mar 22, 2024
Glad the RMA fixed it. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
CaptiveBolt
Feb 03, 2024Aspirant
They’re both hardwired and reading as good
Feb 03, 2024Guru - Experienced User
Direct connected to the RBR or is there a LAN switch in between the RBR and RBS? If so, Brand and model please...
- CaptiveBoltFeb 03, 2024AspirantHey Furry- they’re both running through a tp link 10 gig unmanaged non poe switch.
- FURRYe38Feb 03, 2024Guru - Experienced User
AH ok. Good. Model of this switch please.
I'm getting some info that NG is investigating this issue when RBS are ethernet connected to a 10Gb non managed switch.
- CaptiveBoltFeb 03, 2024AspirantIt’s a TP LINK TL- SX1008. the leds always show the throughput as being 10 g. The satellites are the only things going through it if that helps.
